Windows are often the most visible aspect of a retrofit but making decisions about them can be difficult with lots of contradictory and technically complicated information out there.
This factsheet sheet aims to simplify that process, focusing on the key criteria to consider. As with other retrofit measures, thinking and planning up front can save time, money and stress later down the line.
Similarly, if a particular ‘look’ is important to you, be clear about this up-front as different window frame types, styles and opening types can have very different aesthetics. So, to help you select the best windows for your home retrofit this factsheet covers ten things to think about…
